Oliver 77 PTO assembly
wreather
08-10-2006 10:49:39
My Oliver 77 has a bad PTO clutch... actually it quit! I need to know what parts to order.... the disc size is in question.....and if there is more than one size , PLEASE help....
J Schwiebert
08-10-2006 18:19:45
 Re: Oliver 77 PTO assembly in reply to wreather, 08-10-2006 10:49:39
It may have quit because the throwout bearing was not greased and it worn out. There is also an adjustment on the clutch. There are 2 friction disks in there. Once you take the rear cover off you will be looking right at the clutch.
oliver tractor
08-16-2006 09:18:07
 Re: Oliver 77 PTO assembly in reply to J Schwiebert, 08-10-2006 18:19:45
Thanks for the info... it's greatly appreciated
bradk
08-10-2006 15:52:30
Do you have a service manual for a 77?
If not you will need it.
Take the PTO rear cover off,and unbolt PTO and pull the assy out along with the long shaft.The service manual is really helpful from here and explains the PTO clutch disassemby and inspection.
Tell us what you need & we'll help ya find it.
~brad
oliver tractor
08-16-2006 09:20:46
 Re: Oliver 77 PTO assembly in reply to bradk, 08-10-2006 15:52:30
thanks for the help.... will look into all replies....
