oliver2655 brakes
Cal Innes
08-08-2006 19:51:40
I am in the process of replacing the entire brake system on the 2655 and a neighbor stopped in and said to check .... some tractors with hydraulic brakes used hydraulic oil rather than brake fluid. It would be my guess that it would be the brake fluid.... anyone know? Thanks, Cal
cal innes
08-09-2006 18:29:52
 Re: oliver2655 brakes in reply to Cal Innes, 08-08-2006 19:51:40
Thanks Larry, I spoke with Maibach Tractor in Ohio and they said it should be hydraulic fluid, not brake fluid, too. My dad always told me never to put oil in a car or trucks brake system because it would swell and warp the rubber seals, so I assumed the same would hold true here too...(well, what do I know) I am in the process of putting it all back together now, but found that the seal behind the brake disc is leaking on one side, so I will have to take care of that first. Cal
Larry from md
08-09-2006 14:03:49
I replaced the master cylinder with one from a car so i used brake fluid.It worked at first, but when the tractor sat for awhile it would stick. Later i changed the brakes to non hydrolic that worked much better.
