Cockshutt 50 water pump hydraulic pump question
John in SD
08-05-2006 14:43:57
The water pump on my 50 (buda 273) is leaking. Could someone tell me who rebuilds these? Also, the hydraulic pump grinds a little when I engage it. I use it to occaisionally lift my 456 mower, should I leave it engaged all the time?
J Schwiebert
08-05-2006 15:15:00
 Re: Cockshutt 50 water pump hydraulic pump questi in reply to John in SD, 08-05-2006 14:43:57
Those water pumps are simple to rebuild. If you can get the seat resurfaced you can do the rest yourself if you have a small press. Questions? Send a reply. Questions? J.
John in SD
08-06-2006 07:44:22
 Re: Cockshutt 50 water pump hydraulic pump questi in reply to J Schwiebert, 08-05-2006 15:15:00
I'm sure I will have questions once I get it off and taken apart. It'll probably be a few days before I get this project started. Thanks.
cskent
08-06-2006 07:22:23
Tell me more about doing a rebuild, I have several that need it. Resurface the seal seat, but new rotary seal and or bearings are they something I can get from my local bearing supply house? Thank You
J Schwiebert
08-07-2006 15:07:40
 Re: Cockshutt 50 water pump hydraulic pump questi in reply to cskent, 08-06-2006 07:22:23
I sent you an e-mail. Let me know if you do or do not receive it. J.
mikefri
08-05-2006 14:53:54
John,
you are only to engage the hyd. pump when the engine is not running. Mike
John in SD
08-05-2006 14:56:58
 Re: Cockshutt 50 water pump hydraulic pump questi in reply to mikefri, 08-05-2006 14:53:54
Thanks Mike. That's what I needed to know. The manuals I have don't mention a thing in regards to engaging it.
