WooHoo!!!
Matt Kane
08-05-2006 14:09:50
I got my Super 55 Running. Got it timed finally after the 6th attempt, and in between I had seen a post on the external hydraulics causing the 3 point to not lift. Well that was it, the main valve was froze up, so I tore down the external hydraulic block, freed the valve, and when it was running I pulled out the valve, and the 3 points rose from the dead. What a good day!! Everything is fixed!
minmoman
08-06-2006 15:09:38
 Re: WooHoo!!! in reply to Matt Kane, 08-05-2006 14:09:50
Thats great!
Matt Kane
08-05-2006 18:28:06
Brush Hogged tonight for about 1/2 hour. Ran excellent, the white smoke at startup is gone, and no more either or preheating. I did notice though I may have to eventually rebuild the hydraulic pump or replace some seals, a little weak but good enough for now. Wow what a difference the right timing makes, and a rebuilt starter.
J Schwiebert
08-05-2006 15:19:06
Good!
