White Farm Equipment loader model 1010
MikeS55d
08-05-2006 09:33:30
I have a tractor with a small WFE loader #1010 that has blown a seal. Disassembling the cylinder for repair seems easy enough. On each cylinder just above the seal retaining nut is a deep slit about 1/8" wide and 1" long. Is there a clip or something else in that slit that I need to be aware of before starting the repair process?
Extensive Google searching has found absolutely nothing on a WFE model 1010 loader and WAY too much JD 1010 information.
icesweeper
08-05-2006 10:42:39
 Re: White Farm Equipment loader model 1010 in reply to MikeS55d, 08-05-2006 09:33:30
I"ve never seen this loader model, but on EBAY there are manuals available, both operators and parts.
Link
http://cgi.ebay.com/White-1010-Farm-Loader-Parts-Catalog-Instruction-Manual_W0QQitemZ230004999373QQihZ013QQcategoryZ11753QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
chuck(Tx)
08-25-2006 19:40:16
 Re: White Farm Equipment loader model 1010 in reply to icesweeper, 08-05-2006 10:42:39
Nice websites thanks
MikeS55d
08-09-2006 13:48:38
Thanks icesweeper, I was able to get a manual for the 1010 loader. As I expected there is a retaining clip down in the slit, the manual shows the trick to getting it out. Also found out that it is suppose to have a "float" position that I have never been able to use, maybe a valve rebuild is in order.
For archival info,
The White 1010 loader was intended for the White Field Boss 2-30 and 2-35 tractors. Max clearance @ full height = 92", Lift capacity @ full height = 1130 lbs., breakout = 1863 lbs.
White manual #432 770, dated July 1979.
