model 1800 engine removal
jim w j
08-04-2006 19:53:10
I am removing an engine from this 1800 and i am not quite sure how to get the live power shaft out of the coupler. I do not have a book on this model but I believe the shaft runs from the clutch through the coupler right to the rear of the trans. The big question what is the best way to remove the power shaft?
gfs
08-05-2006 18:23:00
 Re: model 1800 engine removal in reply to jim w j, 08-04-2006 19:53:10
fairly simple, remove o-rings, snap ring and plug, then take a long bolt thread into the shaft and pull out. Most times you have to turn the shaft to get the splines to align and allow removal. HTH.
jim w j
08-05-2006 19:11:06
 Re: model 1800 engine removal in reply to gfs, 08-05-2006 18:23:00
thank you for the reply GFS . i will try this in the morning.
