Nebraska Test #875 876
Vernon
08-04-2006 08:26:15
I would like to know the fuel consumtion of the Oliver 1850 Gas.
Vernon
08-04-2006 11:33:10
 Re: Nebraska Test #875 876 in reply to Vernon, 08-04-2006 08:26:15
Thanks Jake, That is what I was looking for.
Jake R.
08-04-2006 11:08:46
Test 875(Nov. 12-24, 1964) was the gas 1850 two wheel drive, gasoline model. Bare weight was 8,935 lbs., raised to 13,965 with ballast added. Maximum PTO Hp was 92.43 with an economy of 12Hp hours per gallon. It had 76.66 drawbar Hp with an economy of 9.83Hp hours per gallon. Test 876(Nov. 16-24, 1964) was a gasoline 4x4 model 1850. Bare weight was 10,605 lbs., raised to 16,225 with added ballast. It put out 92.92 PTO Hp with an economy of 11.47Hp hours per gallon. Maximum drawbar Hp was 84.52 with an economy of 10.37 Hp hours per gallon. The book notes both tractors were tested in 4th gear, Hydra-Power range.
newter haven
08-05-2006 21:27:29
 Re: Nebraska Test #875 876 in reply to Jake R., 08-04-2006 11:08:46
Are you saying 12 gallons per hour?
N
08-09-2006 21:38:06
 Re: Nebraska Test #875 876 in reply to newter haven, 08-05-2006 21:27:29
No, you get 12 horsepower for an hour out of every gallon of gasoline.
Put another way, it takes a gallon of gasoline every hour for each 12 horsepower.
So, if you actually ran it at it's full rated capacity for an hour, it would burn just short of 8 gallons (92/12).
1755
08-09-2006 16:34:46
I think Horse power hours per gallon is rated at max horse power for the tractor tested I bet no carborator is set exacly the same so it is a ges that your tractor is the same but probly burns less I am sure Oliver picked the best tractor to send so it would look good they might have turned it up a bit
