310 ?
Capt. Ollie
08-01-2006 04:04:07
I have a old 310 diesel with the Lanova combustion chambers. Is it possible to swap heads and convert it to direct injection? I'm looking for the easiest (cheapest) way to make more power.
ohio dick
08-02-2006 22:10:20
 Re: 310 ? in reply to Capt. Ollie, 08-01-2006 04:04:07
I changed my 1650 over to direct injection i was overhauling it at that time. I didnot gain any power or make it start any easier in cold wheather but throtle responce is better. It did cut down on exaust smoke.
J Schwiebert
08-02-2006 03:41:42
You realize this involves not only the head but both manifolds, fuel injection lines, fuel injectors, etc. Also not all direct injection heads are the same either.
ejr-IA.
08-01-2006 19:20:33
Go to a agco dealear and compare head gaskets I think it will work .The line up pins might be oposite though I was told no big deal.
ejr-IA.
08-01-2006 14:21:57
For one thing you would have to change the pistons to the ones with the combustion cup in the piston.Also you will need the right 310 direct injected head because of head bolt size and water passages.
Capt. Ollie
08-01-2006 19:13:59
 Re: 310 ? in reply to ejr-IA., 08-01-2006 14:21:57
So the head will fit? By fit, I mean the bolts, oil and water passages will line up?
ohio dick
08-02-2006 09:28:16
 Re: 310 ? in reply to Capt. Ollie, 08-01-2006 19:13:59
This will also take a different camshaft.
Capt. Ollie
08-02-2006 16:18:06
 Re: 310 ? in reply to ohio dick, 08-02-2006 09:28:16
I realize this would be a lot of work. I was curious to if it was possible. I guess the real question is HOW MUCH MORE HP WILL A DIRECT INJECTION MOTOR MAKE COMPARED TO A LANOVA STYLE MOTOR?
