Super 55 with oil in radiator
Paul Warren
11-14-1999 18:19:18
I recently purchased a 55 tractor that was taken apart for gasket replacement. Apparently the tractor had oil in the coolant. The previous owner tore the head off the tractor, had the valves ground, and replaced the head gasket. In the mean time he lost interest in the project as a divorce was pending. I have 2-questions. 1. If a tractor has oil in its coolant, is it likely that replacing the head gasket will cure the problem (the tractor apparantly ran "like a top previous to the dissassembly")? 2. The fellow coated both sides of the head gasket with what looks to be a non-hardening variety of Permatex and then loosely set the head back on the block (without tighening). Should I start over with a new head gasket or will the gasket be alright if I just continue with the assembly?
Jake
12-13-1999 21:59:31
 Re: Super 55 with oil in radiator in reply to Paul Warren, 11-14-1999 18:19:18
Trying to cure a problem that you know if it even exists by pouring stuff into the radiatior is not going to cure anything. Oil in the rad usually caused by a blown head gasket or warped head for a few bucks replace the gasket and have the head milled [also magnifluxed for a crack]
ROBERT
11-18-1999 20:39:49
oil in the rad is usly cossed be an oil cooler
that has a hole in it.the eng oil is at 30 psi
and the coolent sys is at 7psi so the higher psi oil gose in to the rad.
ROBERT
charles
11-16-1999 16:43:11
First of all make sure that the oil is not a machining coolant souable oil mixed in the water they will sperate, but when mixed (say by water pump)will be white like milk hence the machinist decription "MOOs milk". I often use that in my equipment that won't anylonger hold antifreez reliably(keeps things from rusting). Engine oil won't mix well in water and will come out very thick.
If your getting some engine oil in your coolant your going to have a whole lot in your crankcase. that and if when your engine is running there should be "little bubbels" (and yes that is an automotive term for comression leaks), rising in your radiator. The coolant level should also rise or fall depending witch way fluids are being exchanged the fastest. (99.9999% water to crankcase)
If you find that it is a leakage problem then that the advice of the previous message first and tighten head bolts. (Very rarly dose this work W/O making things worse because the head gasket is probly toast). If the trouble could be cylinder
liners then read the next paragraph because thats the best I know for the leaky liner syndrome.
All else fails and an easy quick fix is desired try BARS LEAK, and nothing else! I have a 45 ford ton and a half with the flathead V-8. The motor has a cracked block thats not repariable. It sucked water somthin fearce. I tried all kinds of stop leak Alunaseal, Prestone stop, ect, ect. Bars leak been holding 5 years and couning.
Other than that your facing a teardown to find the problem. But I'll bet with 95% confindence that it justs a soluable oil to hinder rust.
Need any addition help contact me here or my e-mail above.
Charles
Did you try Justice Brothers Radiator Stop-Leak?
11-16-1999 22:51:12
 Re: Re: Super 55 with oil in radiator in reply to charles, 11-16-1999 16:43:11
cas
11-18-1999 12:10:29
 Re: Re: Re: Super 55 with oil in radiator in reply to Did you try Justice Brothers Radiator Stop-Leak?, 11-16-1999 22:51:12
no I've never seen that
Louis G
11-18-1999 23:06:50
 Re: Re: Re: Re: Super 55 with oil in radiator in reply to cas, 11-18-1999 12:10:29
The JB Radiator Stop-Leak works great. It stops leaks and is safe to run in the cooling system all the time, as it will NOT clog the heater core or radiator. Justice Brothers Radiator Stop-Leak maintains its seal despite the extreme pressures and maintains this seal beyond the effective period of other products.
SEALS LEAKS IN RADIATOR AND BLOCKS
STOPS HEAD GASKER SEEPAGE
REDUCES RUST AND SCALE
NON-CLOGGING
LUBRICATES WATER PUMPS
NEVER LEAVES AN OILY FILM OR SCUM
COMPATIBLE WITH CONVENTIONAL ANTI-FREEZE
NOT HARMFUL TO HOSES OR RUBBER
HOMOGENIZED-EASY TO USE
SAFE FOR ALUMINUM BLOCKS
JB, not availiable in discount chain stores
11-18-1999 23:11:02
 Re: Re: Re: Re: Re: Super 55 with oil in radiator in reply to Louis G, 11-18-1999 23:06:50
Elmer
11-15-1999 15:50:50
Permatex usually stays tacky, and usually the gasket is manufactured with sealing agents that react when the tractor is warmed up. If he used a new head gasket i would go ahead and torque it down. Do you need an operators manual for it, I have one that i can copy for you. Just send me an email if your interested.
