Super 77 clutch problems--have I cured them??
Dondrills
07-27-2006 19:04:27
Over the yrs pedal got to where you had to push to very end of travel to release. Adj was to end. Tore apart few days ago. Relined disc. New throwout B too. Did test and still same. Have to have rod screwed all way out to make work. Now sent pressure plate in for rebuild. should this cure my problem?
J Schwiebert
07-28-2006 06:06:45
 Re: Super 77 clutch problems--have I cured them?? in reply to Dondrills, 07-27-2006 19:04:27
Did you change the pilot bearing? As the clutch wears the free travel gets to be less. When a new disk is installed and you have a lot of free travel you have a problem with the ends of the release levers in the pressure plate being worn and or set at the incorrect height. Questions?
Dondrills
07-28-2006 09:10:05
 Re: Super 77 clutch problems--have I cured them?? in reply to J Schwiebert, 07-28-2006 06:06:45
Yes, I feel the pressure plate fingers are too low. I think when I get the plate back it will cure the problem. Thanks
