3 5/16 diameter shaft?? Rear axle?
Tyler-MO
07-25-2006 11:52:01
I'm trying to repair a two-way integral plow that uses a 3 5/16" diameter x 33" long solid steel shaft that the plow pivots on. The original is broken and I need to find a substitute for it.
I intend to use an tractor rear axle shaft for this purpose. Can anyone out there tell me of any tractor that used this size axle shaft (it can be longer than 33" but not shorter).
Thanks for any help provided!
Tyler in Missouri
old
07-25-2006 17:58:12
 Re: 3 5/16 diameter shaft?? Rear axle? in reply to Tyler-MO, 07-25-2006 11:52:01
What part of Missouri are you in. I might be able to help you with your problem. E-mail is open
