OLIVER CLUTCH
SCOTT MCKELVEY
07-25-2006 07:24:39
Please help,
I have an oc-3 crawler with a stuck clutch, It's been sitting for 20+ years, and is stuck in the engaged position so I can't get it into gear when running, I would like to avoid splitting the tractor if possible, any suggestions appreciated THANK YOU
old
07-25-2006 07:39:25
 Re: OLIVER CLUTCH in reply to SCOTT MCKELVEY, 07-25-2006 07:24:39
You might try blocking/tieing the clutch pedel down and also spray brake cleaner or carb cleaner in the starter hole and leave the pedel down for a few days. Then 2 or 3 times a day spray it and also turn the engine over so it gets all over the clutch.
