Oliver 88 hard starting
Marc Smothers
07-19-2006 18:24:35
My nephew just got done overhauling our 88. It starts good cold, but when it is warm it won't start. Any ideas??? Thank you, Marc
Matt Kane
07-20-2006 15:43:51
 Re: Oliver 88 hard starting in reply to Marc Smothers, 07-19-2006 18:24:35
Sounds like the injection pump.
Marc Smothers
07-20-2006 14:53:21
Sorry about that it is diesel.. I am beginning to believe the valves are too tight and the injector pump needs work... Thank you, Marc
J Schwiebert
07-20-2006 17:52:48
 Re: Oliver 88 hard starting in reply to Marc Smothers, 07-20-2006 14:53:21
If you find out it is the pump then the plunger is worn in the hydraulic head. That is one reason they put another fuel filter on the Supers . If it was me and it only has the single LS filter assembly I would also add one of those square Roosa maters on behind the engine if it is a "show tractor". FYI. Last time I priced a hydraulic head assembly as in plunger and head they are matched $800.00. Questions?
J Schwiebert
07-20-2006 17:51:34
If you find out it is the pump then the plunger is worn in the hydraulic head. That is one reason they put another fuel filter on the Supers . If it was me I would stick one of those square Roosa maters on behind the engine if it is a "show tractor". FYI. Last time I priced a hydraulic head assembly as in plunger and head they are matched $800.00. Questions?
bradk
07-19-2006 20:36:03
Does the starter spin the engine over OK? If so,I'd say the lifters are set too tight.~brad
old
07-19-2006 20:17:16
Gas or diesel?? If gas it could be the timing, or carb problems. Shoot most of the time I can't get my hand off the starter button fast enough on my S88 weather its hot or cold and that includes when its 32 out. Picture of it in the web page
scottf
07-19-2006 19:09:25
I assume it's gas. If so, I would check the coil.
