770 hydraulics
alberta dave
07-18-2006 08:13:47
Well my hydrualic pump on the old 770 is finally pooched. Not a bad run considering it when it was built. Can rebuilt/exchange pumps still be found? If it was working would it have the power to raise and lower my V-rake arms?
Should I consider putting a new pump on the front to get a higher presuure system?
I am always willing to listen to sound advise.
centerplate
07-19-2006 07:37:31
 Re: 770 hydraulics in reply to alberta dave, 07-18-2006 08:13:47
I have all the parts to rebuild pumps. Let me know what you need.
old
07-18-2006 09:32:31
I have a 77 with home made 3 point on it and I can lift so much that the front of the tractor will come up, no I don't do that often and only once for that matter. So yes the hyds on board should be strong enough to do what you want. Shoot I know of a 770 with loader that runs off the on board pump. This site and or valuebilt should have new/rebuilt pumps. Of couse your problem may not be the pump but the relief valve, or seals etc.
