Any way to put a starter on 80 RC
Paul G. in Mn
07-17-2006 17:08:54
I have a 1938 80 RC and wonder if anyone has made a way to put electric start on one with out looking to funny? Would be nice to use it a little more with out pulling or belting Thanks Paul
James Tierney
07-19-2006 20:22:54
 Re: Any way to put a starter on 80 RC in reply to Paul G. in Mn, 07-17-2006 17:08:54
I purchased an 80 parts tractor several years ago that had an automotive flywheel mounted on the belt pulley shaft, and a starter mounted on the top cover - fairly unsafe, but it appeared to have worked at one time. My 80 Row Crop also has a starter, but I have added an industrial frame - it is only for pulling, so I made an adapter to mount the front end - it looks nice, but is far from original.
James
RAB
07-17-2006 23:45:15
No. Unless you want to fix up a drive for the power take off?
Generally they are no problem starting, excepting the handle is a bit at the wrong angle compared to the standards!
If you are having to pull it or start it with a belt, your impulse coupling may need some attention.
Regards, RAB
