ID my Oliver 550, generator issues, water pump iss
David Lee Hawki
07-12-2006 19:57:49
I would like to ID my tractor. I need a new water pump and generator.
Engine Block Numbers: (All near ea. other on blk)
180228-G
ILB-100-B
6168
K5
Under Seat:
102125A
My pump is leaking out of the weephole. I changed gasket to no avail. The only numbers I see on the pump are:
8A13 Stamped on the nozel carrying water out.
3971 Stamped on the pump core.
M1 Stamped by itself, no other numbers with it.
NM Stamped by itself, no other numbers with it.
Generator Tag: Delco Remy (or similar to Remy)
101974 5612 (The numbers were just like they are here with the space in between. There may have been something else in between, I just couldn't make it out. It may have only been a dent.)
Thanks, David
Mike (WA)
07-14-2006 08:25:31
 Re: ID my Oliver 550, generator issues, water pump in reply to David Lee Hawkins, 07-12-2006 19:57:49
You might check the voltage regulator- mine is strapped to the generator, and is conveniently located square under the drip line of the hood. If you have to keep it outside (mine is on the manure spreader all winter), you'll go through regulators pretty fast due to corrosion from moisture. Would love to switch to alternator, but my power steering pump drives off the back of the generator.
J Schwiebert
07-13-2006 03:47:38
You have the earlier 550. I can send you a trouble shooting chart for the generator. For the waterpump you do not have an Oliver Water pump by those casting numbers. The seal is bad in the water pump. You must be used to automotive water pumps. Tractor pumps are rebuilt because it is so much cheaper, Same for the generator. Does your tractor still have a serial number tag yet? It is located by the clutch petal. I also sent you an e-mail J.
