550 - Need water pump, generator, tractor ID
David Lee Hawki
07-11-2006 20:00:50
My pump is leaking out of the weephole. I changed gasket to no avail. The only numbers I see on the pump are:
8A13 Stamped on the nozel carrying water out.
3971 Stamped on the pump core.
M1 Stamped by itself, no other numbers with it.
NM Stamped by itself, no other numbers with it.
Engine Block Numbers: (All near ea. other on blk)
180228-G
ILB-100-B
6168
K5
Under Seat:
102125A
Generator Tag: Delco Remy (or similar to Remy)
101974 5612 (The numbers were just like they are here with the space in between. There may have been something else in between, I just couldn't make it out. It may have only been a dent.)
Thanks, David
