Steering Gear unit or steering wheel?
brian61
07-08-2006 17:18:08
I noticed when I was on the tractor today {Super 55} steering wheel is catching when you turn, kinda slipping. Not sure what is wrong with it yet, bits of plastic and rust are falling out of the steering wheel when I turn it. By the time I got it back to the barn there was quite a bit of rust and plastic on the tractor below the steering wheel. Not sure if the steering wheel is slipping on its own spline or if it is in the steering gear unit. Got any ideals what it might be..?? Took the center cap and nut off but I couldnt get the steering wheel to come off [just pulled and tapped it a few times] started getting dark on me so I had to quit. Is there a trick to getting steering wheel off..??
Thanks, Brian
