Cylinder Sleeve on Super 88
jimfitzgerald-ia
07-06-2006 21:01:36
third party image
Im working on restoring a Super 88 Diesel. I"m trying to decide if I need to replace the cylinder sleeves. The picture is the worst looking sleeve of the 6. Any thoughts/info is appreciated.
RAB
07-06-2006 23:01:48
 Re: Cylinder Sleeve on Super 88 in reply to jimfitzgerald-ia, 07-06-2006 21:01:36
Not sure what you mean by worst.
Get them measured for wear - oversize, ovality, taper.
Can"t tell from your picture as my micrometer couldn"t cope with that.
All the rest may be just as bad as this on measuring them up.
Also need to measure up rings, grooves, skirts on pistons.
Check that all fit tolerances are within sensible specs.
You don"t say what duty cycle tractor will be used for when "restored" or whether your restoration is to get it running or for returning it to near "as new" condition.
What about bottom end? Fitting all new sleeves/pistons may precipitate a failure in the crank department.
If you need to fit new pistons, the extra cost for the sleeves is probably worth saving up for.
Regards,RAB
