? about 1650
ORF
07-05-2006 20:11:57
Just got a 1650 gas. Have a question.
What is the fuel consumption /hour of this tractor? Under both light load and heavy load?
Jim@concordfarms.
07-06-2006 11:05:30
 Re: ? about 1650 in reply to ORF, 07-05-2006 20:11:57
My 1650 will use 5.6 gal. per hr. pulling a 4-14" semi-mount plow. Throttle down and gear up for light loads like raking hay or cultivating and it will use about half that amount.
Beck
07-06-2006 07:00:14
Nebraska tractor tests report 5.696 gallons per hour under 100% load. I doubt that you would ever achieve 100% load under actual field conditions. They do not test them under light load since that is a vague term. From experience I can tell you they are substantially thirstier than a diesel of the same model, especially under lighter load conditions. With gas at $3.00 plus a gallon, a gas tractor is hardly practical unless you put VERY FEW hours per year on the tractor.
evilboweviel
07-06-2006 10:58:46
 Re: ? about 1650 in reply to Beck, 07-06-2006 07:00:14
unless those are winter hours then a gasser makes a lot more sense.
my 1650 diesel plowing 22 acres used about 3.5 gallons a hour pulling 4-16 10" deep in 2cd low 2400 rpm keeping water temp less than 210 in 80degf weather
Ron
