550 pto oil leak at shaft output
greg mmmm
07-04-2006 05:49:04
where the pto output shaft comes out of the back end of the tractor, its leaking oil. Can i remove the 4 bolts and pull out the pto so i can replace the seals? if not how would it be done.
Skywalker3
07-04-2006 08:39:42
 Re: 550 pto oil leak at shaft output in reply to greg mmmm, 07-04-2006 05:49:04
Just replaced mine since I had the gear oil out of it anyway. Easy fix to stop the leak. I picked up the seal at Agsco dealer, but any machine shop should be able to match it. I cleaned the pto shaft with emery cloth first so it was nice and smooth.
Super 55
07-04-2006 08:15:10
Yes, but make sure you drain the final drive. There is a gasket, a seal and a felt washer.
