310 Sleeves in 880 Block
unknown2
07-03-2006 12:27:46
Anyone know if 310 Sleeves would fit in 880 Block?
Bryce
07-05-2006 23:57:49
 Re: 310 Sleeves in 880 Block in reply to unknown2, 07-03-2006 12:27:46
I used 1800 sleeves bored them to 4.030" no problem.
J Schwiebert
07-03-2006 17:55:02
What is your defination of fit? Also tell me what your intent is with this question. I think I know, but I want to here it from you. J.
unknown2
07-04-2006 03:46:43
 Re: 310 Sleeves in 880 Block in reply to J Schwiebert, 07-03-2006 17:55:02
Yes I am Interested in Getting to 310 Cubes.with Stock Block I know aftermarket Sleve Piston Kit will get me to 283 but thought I could use 310 Rods and Pistons and Stroke Crank to get to 310 looks like it may work? Thanks
J Schwiebert
07-04-2006 07:39:53
 Re: 310 Sleeves in 880 Block in reply to unknown2, 07-04-2006 03:46:43
Guy down here used to pull an 88. He had it stroked a half inch. If you are thinking 3-7/8, does M & W still have a 3-15/16 gas kit for an 1800? I also repaired a head for an 88 a long time ago. He also showed me the sleeves which were bored to 4 inch and he used John Deere Pistons. Now those sleeves were thin! I have also seen steel slevess for a little extra strength. How about a little other work? I looked at a 4.250 bore 88 the other year, half inch stroke would make it a 339. Your 310 sleeve will fit in the hole but they are longer so only one o-ring will catch I have seen it done. What have you done to the head, manifold and cam?
A.P.
07-04-2006 15:19:06
 Re: 310 Sleeves in 880 Block in reply to J Schwiebert, 07-04-2006 07:39:53
To clarify things, the 4 1/4" bore with a stoke stroke gives 340 cubes. A 1/2" stroke (4 1/2") with a 4" borewill give 339 cubes. A bore of 4 1/4" with a 4 1/2" stroke gives 382 cubes.
A set of 3 15/16" piston and sleeve set for which 1800 series engine (A, B or C) works? I"ve heard this before but do not know which set works or isn"t there a difference?
unkown2
07-05-2006 04:12:03
 Re: 310 Sleeves in 880 Block in reply to A.P., 07-04-2006 15:19:06
Ok here is another Question -Will 310 fit in 880 with no modifications to tub and bell housing? Thanks
J Schwiebert
07-04-2006 20:14:39
Sorry for the math confusion. I was thinking of the 339 Hercules which is a 4 x 4-1/2. I was thinking it was 4-1/4 X 4.5. Oh well next time I guess do the math.
JD hauler
07-03-2006 18:44:04
I would guess the man wants to know if he can build the motor up some, probably pulling, I dont think the question was too awful hard J.
