WOOHOOOOO!!!! IT fired!!!!!!!!!
Iowa Jim
07-03-2006 05:01:50
Well I re-bled the injector lines and gave my 1800 a shot of ether and she fired right up!!! Man am I excited!!
The only problem now is that the low idle is set too high. However, the 1800 Service manual I have is dated before the C series so it references a different Roosa Master injection pumpt than the one I have. Anyone have a quick reference for adjusting the high and low idle?
Jim
Ken L
07-03-2006 15:33:16
 Re: WOOHOOOOO!!!! IT fired!!!!!!!!! in reply to Iowa Jim, 07-03-2006 05:01:50
By the arm that's hooked to the throttle shaft of the pump where the throttle linkage hooks up, there should be two small bolts that limit the travel of that lever. One is for high speed and the other for low speed. With the engine off, pull the throttle lever all the way to low speed and see if the lever is touchng one of the bolts. If it is against one of the bolts, you can back that bolt out enough to get it to the right idle speed BUT, if you just had the pump rebuilt, this will probably void the warrantee. Talk to the rebuilder first. If that lever isn't touching the bolt, you will probably have to adjust the throttle linkage enough so that it just bumps the bolt.
Don-Wi
07-03-2006 05:25:11
Hey, Congratulations!!!!
I know how you feel to get something running again, I had the same feeling last summer when I heard my 1600 fire for the first time in over 5 years. As far as the pump, is there a bump screw to adjust the linkage, or how far it idles down? Only thing I can think of, may or may not be able to adjust the linkage.
Donovan from Wisconsin
