Oliver 88 torques
Sheila Cole
07-01-2006 16:00:49
I know nothing about Olivers and my local TSC has no books.
I need specs for head bolt tightening. I put a head gasket in was putting water in oil.
J Schwiebert
07-01-2006 19:49:10
 Re: Oliver 88 torques in reply to Sheila Cole, 07-01-2006 16:00:49
First of all the head torque and valve setting for the gas engines is different from a n 88 diesel as is the valve clearance. Did you check any other cause of the coolant getting into the pan? J.
Sheila Cole
07-02-2006 04:27:25
 Re: Oliver 88 torques in reply to J Schwiebert, 07-01-2006 19:49:10
No I did not assume it is head gasket. It is a gasoline engine.
