White 2-63-15 Backhoe
Bryan Schubert
06-29-2006 20:34:21
I have a White 2-63-15 backhoe with a 6 cyl deisel engine. I have heard it is the same engine that came in an Oliver. Does anyone know what engine this is?
hoot 66
06-30-2006 15:43:52
 Re: White 2-63-15 Backhoe in reply to Bryan Schubert, 06-29-2006 20:34:21
Tramway is right., it is the lanova system. Iguess I was thinking of the 1655.
hoot 66
06-30-2006 04:23:30
I have one that I have had for 27 years. It has the same engine as a 1555. it is direct inj. Its a very stout machine.
J Schwiebert
06-30-2006 03:58:08
Your 2-63 is the industrial version of an Oliver 1550/1555 Tractor. 2 means 2 wheel drive, 63 is the engine flywheel horsepower and 15 if for the back hoe (digging depth) If I remember correctly. Engine is 232 cubic inch. Questions?
Tramway Guy
06-30-2006 05:55:27
 Re: White 2-63-15 Backhoe in reply to J Schwiebert, 06-30-2006 03:58:08
Hoot66 says his was direct injection..I thought the 232 was only indirect?
Or maybe his was the 1650/55 engine?
Bryan schubert
06-30-2006 06:59:27
 Re: White 2-63-15 Backhoe in reply to Tramway Guy, 06-30-2006 05:55:27
Thanks for the info it will help me alot. My book gives me the valve lash but dose anyone know the head bolt torqe.
J Schwiebert
06-30-2006 08:48:22
 Re: White 2-63-15 Backhoe in reply to Bryan schubert, 06-30-2006 06:59:27
I am sure I had the head torque. Let us double check all this stuff. Behind the starter are 3 casting numbers. Please send me those numbers. Also look and see if you can find a serial number tag. Thanks J.
Bryan schubert
06-30-2006 14:08:37
 Re: White 2-63-15 Backhoe in reply to J Schwiebert, 06-30-2006 08:48:22
I found 2 casting numbers that is all i can see without taking off starter. 185320 1609184
J Schwiebert
06-30-2006 16:24:55
 Re: White 2-63-15 Backhoe in reply to Bryan schubert, 06-30-2006 14:08:37
You have a 1550/1555 industrial. The engine is a 232 cubic inch engine. The last casting number you gave me the 4 is an A. It is the Oliver casting number for the block. The 185 number is the Waukesha number. You asked for the head torque: I have it but first tell me if you are checking it or if you had the head off. Send me a phone number too. J.
