oliver 1800 L.P. Gas won't start?
Jeremy T. Scott
06-29-2006 20:30:49
I have an oliver 1800 tractor that does not get L.P. fuel. It sparks and get's fire, but no fuel. The tank is filled and I suspect the fuel filter but am not sure, is there a way to test and see if that's it or does it sound like a regulator problem? Thanks, Jeremy
e-mail@ [email protected]
or call @ 405-453-7407
Jeff Oliver
06-30-2006 19:06:58
 Re: oliver 1800 L.P. Gas won't start? in reply to Jeremy T. Scott, 06-29-2006 20:30:49
I have a C series up in the shed. When you turn the valve on can you hear the gas going through the valve? If so you might check the regulator and also look on it and see it if has a purge button.
We had a JD 720 LP that we had to replace the regulator on and messed with it for a month trying to get fuel to the carb. Friend who knew what he was doing came out and purged it and it run fine. If there is one purge it until you get liquid. I'll chekc my book tonight and see if it says anything about it also.
