Welcome me to the family!
John Baxter
11-08-1999 17:25:14
Well, I did it... I purchased my first tractor... an Oliver Super 55. I have yet to see it... but I am proud none the less. It may have a bit of a problem, it sat in a shed for 7 years. The PTO turns even when not engaged. My father-in-law (aka consultant) thinks this is probably because the PTO clutch is tight after sitting so long... does this sound like a serious problem? He thinks that if an implement it attached it will stop turning, but this is guess work, like I said we have yet to see it.
Bob Skurka
11-10-1999 05:37:40
 Re: Welcome me to the family! in reply to John Baxter, 11-08-1999 17:25:14
I bought my Super 55 Diesel sight unseen too! To this day I have no regrets. I had a picture of the tractor and heard rumors my ran well. Truth be told, mine looked like hell but it did run. I've had fun and know I got a great tractor. With any luck you will be as happy about yours as I have been with mine.
By the way, I bought a car the same way. Last night it was unseasonably warm, we dropped the top and went out for ice cream. I have a good wife, she puts up will all my foolishness!!!
Dennis Hawkins
11-10-1999 04:01:01
Congratulations! You didn't say if it was Gas or Diesel. If it is gas, the points in the distributor will be a constant source of hassle. See my article at:>Link
As far as the PTO, if it spins, then leave it alone. The PTO clutch system on this tractor is not very well designed and the parts are difficult and expensive to obtain. One thing about the PTO is that you should always leave it engaged so that it will turn constantly. Leaving it disengaged causes the clutch plates to wear out prematurely. If you need it to stop so you can hook something up, just turn off the engine.
Other than that, the Super 55 is a really good tractor. We've had ours for 30 years now and it has always been a good one. I just moved a pile of dirt with mine the other day.
John Wilson from WI
11-15-1999 13:38:34
 Re: Re: Welcome me to the family! in reply to Dennis Hawkins, 11-10-1999 04:01:01
Dennis,
I also own a Super55 and am very happy with it. I have to thank you for your article on the 6-12 volt conversion. It was very helpful when I converted mine and also added electronic ignition and an alternator. She runs like a top now.
Could you expand a little more on your advice to keep the PTO clutches engaged at all times? This is the first time I have read this about the Super55 or any tractor for that matter. It doesn't seem very safe to be doing this.
Thanks for responding.
John
Don N
11-16-1999 10:23:31
 Re: Re: Re: Welcome me to the family! in reply to John Wilson from WI, 11-15-1999 13:38:34
John, I agree with you that leaving the PTO engaged is NOT a safe practice. I do not know about the PTO on the Super 55 or 550, but my dad had a 77 and 770 (I still have the 770) and we have had very little or no trouble with the PTO. We always disengaged it when not in use and whenever we wanted to stop the implement operated by the PTO. One piece of advice, when engaging the PTO do not let the clutch slip for a long period of time. Slipping the clutch is the biggest cause for problems. Do not jerk it into gear, but be firm. If it is like the 770 be sure it is adjusted so the lever snaps into position when engaged.
Good luck with your tractor.
Don
Mongo
11-09-1999 14:31:13
Wise choice. They are easy to work on. The PTO clutches are easier to adjust on them than most other models. Most will turn if nothing is attached to prevent it. When properly adjusted the PTO lever should "POP" in and out. If it feels mushy, then it either needs adjusted or in need of some fixing. Adjusting takes only minutes, let us know if you need something.
jerry f
11-09-1999 09:33:21
My 55 has the same problem with the pto, I havnt got around to fixing it yet, but if I put the drive from my mower on it when it is shut down it works properly, but I suppose it might be causing some wear on the clutches using it that way
Danny Yerks
11-09-1999 08:02:41
Earlier you were comparing the Oliver to a Ferguson. What made you choose an Oliver? I'm also curious why you bought it sight unseen (I rented an apartment that way once and regretted it!) and what you paid for it. Good luck getting it fixed up (I may be joining the "family" soon!)
Paul STanley
11-08-1999 21:53:39
Congrats, it really is a very nice tractor and it is from a good family, Oliver. Kind of wondering how you bought it without looking first. Almost as bad as me. I bought my first tractor in less than 30 minutes inspection. The fever had ahold of me. I never regreted either. You may just have to adjust the pto clutch, or do a little work on it. The best thing is you'll get to learn about it. I got the mauals from the store at this site. They are good and have everything from the Super 55s to the 880s in them.
highboyford
11-08-1999 18:30:06
ahh good choice,and I can just picture how wide you are smiling right now nothing like your very own tractor.I would check your wiring out too those mice seem to think it tastes good or something.I would go to the bottom of this board and order a couple books for the little hotrod,good luck with the pto.
