Matt Page
06-26-2006 12:02:34
O.K. need some advice and information folks... Found a 2150 in a guys barn, he wants to sell, said make him an offer and haul it off. Said he'd had it several years and the main thing wrong with it was nobody knew anything about it or how to work on it. We jump started it, and it started immediately although it has obviously been sitting for a few years, sounds great, good oil pressure, but smokes alot. The steering doesn't work at all and the hydraulics to lift the dozer blade on the front worked very slowly and only when the engine was run up. Three point hitch on the back does nothing, pto works, and he didn't know it had an over/under, had only used the six main gears. I'm unable to drive it because of the steering. Will need a rear and front tire, tin looks good, exhaust manifold is cracked, patched, and leaks, has original canopy, planetary rear end. It's 9'10" accross the rear tires. Hour meter and rmp doesn't work since 18xx hours. I love old tractors and engines and know this to be kind of a rare bird, and have uses for it, can also get by without it. Wanted to hear some Oliver guys' opinions and if I somehow get it over to my place will be back here often I'm sure. Thanks, Matt.
