Super 55 PTO Clutch Basket
RCP
06-25-2006 05:52:52
I am putting the PTO clutch back together, and need to tighten the spanner nut in the bottom of the clutch basket. Can anyone tell me the correct torque?
Thanks
Rich
jake4
06-26-2006 07:39:54
 Re: Super 55 PTO Clutch Basket in reply to RCP, 06-25-2006 05:52:52
This normal the hub is splined on both ends rides on 2 roller bearings and 2 ball bearings to the rear hub driving nothing. Once the discs are in place there will be a drag.
jake4
06-25-2006 08:32:39
The book calls for 150 foot pounds of torque, then stake the threads in 3 location. I made a spanner from a 2 ft lenght of black pipe [2" in ID]. Most people use a hammer and chisel to remove. I could send a photo if needed. LOL
RCP
06-26-2006 03:26:48
 Re: Super 55 PTO Clutch Basket in reply to jake4, 06-25-2006 08:32:39
Thank you, I also made a spanner wrench from a piece of pipe. I am concerned because after I tightenened the nut, the basket and shaft were still able to move in the transmmission case. Is this normal??
Thanks
Rich
