Oliver 550 Overheating
David Lee Hawki
06-24-2006 17:04:43
My tractor is overheating with only marginal work. I'm using a 6 ft. bush-hog. I'm mowing 2 ft. weeds. I've replaced the thermostat and hoses. The radiator is flushed, clean and working. I'm using 50/50 anti-freeze / water. The water is coming out of the overflow tube next to the radiator cap. Could my radiator cap be bad? The water is very hot but my be within normal operating temp. My temp guage doesn't work. I will be getting another radiator cap, however, I would love to hear other thoughts.
Thanks, Hot In Dallas
Farmritch
08-06-2006 21:44:30
 Re: Oliver 550 Overheating in reply to David Lee Hawkins, 06-24-2006 17:04:43
HGow about timing??
RAB
06-25-2006 11:50:17
Ideas/thoughts?
Pressure cap, head gasket, bad radiator, loose fan drive belt, engine block solid with deposits, retarded timing, lean mixture, cracked head, vacuum advance disconnected allowing air into manifold, clogged radiator matrix, water pump, cooling system overfilled, manifold leak. Want anymore?; "cos I"m runnin" out of ideas!
Regards, RAB
old
06-24-2006 21:18:32
Let me guess you flushed it with the parts store stuff, right??? If you did you spent $$ that wasn't worth it in my book. BTDT and lost. Heres what I would do. DRain the system, then fill with vinagar, 100% then run it till hot. Let it cool a few hours and then drain it. Then rig up a back flush to the engien block drain so you can hook a garden hose on and hook it up turn it on and then goo have a 6 pack. or go watch about 2-3 hours of stargate etc. Then drain/turn off the hose and refill with anti freezre. My 77 would over heat that way til I did that and it hasn'y gotten over 190 since I did that no matter what I pull or do with it
