OC3 Oil Pressure Pick Up
ChrisL
06-23-2006 10:49:50
Anyone have an idea where I can pick up engine oil pressure on an OC3 crawler. e.g. plug my gage in the motor
J Schwiebert
06-23-2006 13:30:21
 Re: OC3 Oil Pressure Pick Up in reply to ChrisL, 06-23-2006 10:49:50
I am going to give you a stupid answer for the minute. Plug into the same fitting the existing gauge plugs into. Now I need to think a minute on where that is. First of all are you just checking the oil pressure or is this to be hooked up for good. Also are you aware there is an adjustment for oil pressure on the left side of the engine. J
ChrisL
06-24-2006 07:38:01
 Re: OC3 Oil Pressure Pick Up in reply to J Schwiebert, 06-23-2006 13:30:21
There is no gauge on the machine and I see no line near the oil filer, yes I am aware of the adjustment.
There is a plug near the dip stick just behind the starter, perhaps this ?
J Schwiebert
06-24-2006 19:32:52
 Re: OC3 Oil Pressure Pick Up in reply to ChrisL, 06-24-2006 07:38:01
I just looked at two of them about an hour ago. Both took the line for the oil pressure gauge from the plug about 1 inch in front of the dipstick.
Larry from md
06-23-2006 16:28:07
On some of those engines there is a t in the line going to the oil filter,and that where the preasure gage line goes.
