oliver re-motor options
JD hauler
06-21-2006 19:46:43
what is the best choice for an oliver 88 remotor, I am new to olivers and want to upgrade an 88 with some kind of bigger motor, can anyone out there give me some options of what will fit in with no mount or frame mods and possible cost on engines. thanks.
Jeff Oliver
06-23-2006 20:12:09
 Re: oliver re-motor options in reply to JD hauler, 06-21-2006 19:46:43
what are you wanting to do with the 88? Around the farm and farm stock pulling just rebuild what you got and since they mostly pull in first gear you'll have plenty. A little hotter, go with bigger M&W pistons and a little head work. Making a hot rod, start with a 1850 gass motor and build the heck out of it.
I heard a guy atalking about a 195 motor at a pull but I had no luck finding one on the net. I was just curious as my pockets aren't nearly deep enough to need one of those.
hehe heck if ya just want to have fun. though a nice ford/ Chevy/ Dodge V-8 in there.. :)
JD hauler
06-24-2006 18:50:57
 Re: oliver re-motor options in reply to Jeff Oliver, 06-23-2006 20:12:09
Jeff, it has the m-w kit and head work, it runs pretty darn good, I pull 15.5 cuts and in div 3 , its a really competitive tractor, but at 283 cid, its also the smallest there, I sometimes have beaten 400+ cid's and 300 + cids, but I have to be perfect and no mistakes, I pull 2nd gear from 4500 to 5500 and it does it well on tacky clay, I have just been thinking of doing another motor and keeping this one around for a spare, I want to keep this motor for a spare so to speak, and it will allow me to keep running until the new motor is done, that is why I dont want to do any more to this one, thanks
JD hauler
06-23-2006 07:15:34
where might one look up on of these motors?
J Schwiebert
06-24-2006 04:51:05
 Re: oliver re-motor options in reply to JD hauler, 06-23-2006 07:15:34
Where are you located? Also remember that these engines are also close to the age of your 88 engine so many have been scrapped. Do anything with Military Surplus dealers? There is also a 197 engine. J.
JD hauler
06-24-2006 18:45:31
 Re: oliver re-motor options in reply to J Schwiebert, 06-24-2006 04:51:05
western pa.
JD hauler
06-23-2006 07:12:10
J Schwiebert
06-22-2006 03:37:07
How large is the bore and stroke now and how large is your check book?
JD hauler
06-22-2006 15:58:21
 Re: oliver re-motor options in reply to J Schwiebert, 06-22-2006 03:37:07
its a 283 motor with m-w , I just knew someone was going to say about the deep pockets.LOL, I hear of 310 motors and 1850 motors, whats the best choice, thats what I need to know, thanks
J Schwiebert
06-23-2006 04:07:46
 Re: oliver re-motor options in reply to JD hauler, 06-22-2006 15:58:21
A couple of years ago I was asked to look at a Buda Diesel at this shop. It is in good rural country and he had a number of "slightly modified" stock engines for pulling. This 88 gas had been modified to take sleeves with a 4.250 bore and it had been stoked to 4.5 so that made it a 339. If yoy find a 195 Waukesha you can also do that plus probably more. I have also seen 88 sleeves bored out to 4 inch but they get a little thin then.
