S55D Eating starters 3rd on in two weeks ideas?
Ken07
06-21-2006 10:57:21
I went to Carquest and bought a starter for 1960 550 diesel since the books do not go back far enough to cover the 1955 S55 diesel I have. It has been converted to key start with solenoid. Anyway, First starter worked for about a dozen starts then got slow then really loud while cranking then grindind then just spun without engaging, second one worked twice then same thing just picked up the third today. Flywheel looks ok just some chewing on tthe face due to the starter problems teeth look good and not worn. Each of the starters were suspected to be the bendix. What would cuase it? Is there a way to shim or does it need it? I'm at a loss for ideas.
J Schwiebert
06-21-2006 12:32:11
 Re: S55D Eating starters 3rd on in two weeks ideas in reply to Ken07, 06-21-2006 10:57:21
I would have to check on the Super 55 model tractors, But when the 550 was introduced the number of teeth on the ring gear changed. That means the clutch in the starter (bexdix to you) requied is different because the number of teeth have to be different. Questions?
