Oliver 1850 Oil Pan Plug
TSH
06-19-2006 10:05:18
So I've rounded off the drain plug ( why did they use such soft metal?). Vice grips won't hold it, wrenches won't do it, and don't use the drill out sets or the hardened tap will break off. Any suggestions? Can I weld a nut on there? Others have told me the plug metal is too soft. I tried dropping the oil pan, but there is no human way to get to the pan bolts that are under the front of the engine unless someone has some tips on that.
Thanks in advance.
Spike in WI
06-24-2006 06:17:06
 Re: Oliver 1850 Oil Pan Plug in reply to TSH, 06-19-2006 10:05:18
I've got a nut welded on my 1850 drain plug also.
schrocky
06-19-2006 11:23:34
welded a grade 8 nut on a working 880 D about 20 yrs ago and we still change oil 3 x a yr with it that way
TSH
06-20-2006 06:56:30
 Re: Oliver 1850 Oil Pan Plug in reply to schrocky, 06-19-2006 11:23:34
Thanks; that I want to try but I"ve been told the plug metal is too soft. I think I"ll give it a try.
