oliver 550 hydraulic problems
brett munsey
06-19-2006 00:59:57
I have a oliver 550 that has no hydraulic pressure by that I mean that neither the three point lift arms or the loader will operate. The loader is run of the auxillary valve directly below and alongside of the seat. I was able to drain the hyd. tank by depressing one of the quick release balls and pumping the oil into a bucket so the pump does generate flow just no pressure. I have taken the top of the final drive off and tore the pump apart and everything looks good inside. Does anyone know where the pressure relief valve is located and is there only one or is there a sperate one for the aux. valve and the lift arms. I also tore apart what looked to be several different reief type valves on lift arm cylinder valve assembly and everything looked good there as well. Any and all ideas would be appreciated. If I ever get this hyd. problem figured out I would like to upgrade to a full power loader rather than the trip bucket gravity down loader I currently have any ideas on how this can best be accomplished? Is there anything I could do internally while I have it tore down or do I need a auxillary pump of the front of the tractor. Thanks for your help
john swanson
06-23-2006 05:11:55
 Re: oliver 550 hydraulic problems in reply to brett munsey, 06-19-2006 00:59:57
i am going to buy a 550 for 4250.00 with loader am i paying to much and do you like the 550 how meny hp. is it and what year is it about???? thanks for the info. Jack
Skywalker3
06-19-2006 07:36:50
I believe your hydraulic fluid must first flow through the external control valve. There is a relief valve in there if it is a factory unit. Check that first. I had a similar problem and tore into the hyd cover area also, only to discover the problem was external. At least you know how it works in there now.
As far as the loader.....I run a fully hyd loader off of the interal pump and it works well. However, I am using some type of a 'power beyond block' for my external hook ups, and not a factory external control valve unit.
I bought a ESPCOR manual on CD ROM. $22.00. It is the full 1400 page Olive manual. Type in ESPCOR manual on EBAY and just give them a call.
J Schwiebert
06-19-2006 02:44:42
There are 2 relief valves. The external valve most likely has some dirt under it. You need to test them. Do you have a shop manual. On your loader and a front pump you need to do some math as to what size pump you need.
