770 slips out of gear
Skywalker3
06-15-2006 18:37:43
Hello, My neighbor has a 770 that slips out of gear. I got a chance to drive it the other day. There is no power booser on it.
When I drove it I noticed a loud "whining" noise coming from the transmission area. Kind of sounded like a hydrostatic drive on a lawn mower. It made the noise when under even a slight load. The noise would stop if coasting down a hill.
When it slips out of gear it makes no noise. The gear slift lever does not move, you don't feel anything. It just gently coasts to a stop. And it slips out quite often.
Thanks for any advice.
J Schwiebert
06-16-2006 18:41:10
 Re: 770 slips out of gear in reply to Skywalker3, 06-15-2006 18:37:43
First thing is to pull the PTO and the hydraulic unit off and look in there. The gears you shift except for the range selector are all on the bottom shaft. I would also pull the pinon shaft cover and see if the nut has come loose or if you have too much endplay.
