ques. about 1650 dsl
Rich Iowa
06-13-2006 18:01:28
I was messing with my tractor this past weekend and came up with a few questions. There's a coolant hose going from the top right front of the block to the thermostat housing that is real spongy, and I'd like to replace it before it goes while I'm in the field. This hose is short and has a sharp (90 deg.) bend, is this a special order hose or can I find one that'll work at the parts store? After the engine warms up, the gauge still runs in the cold, I'm going to replace the thermostat and see if that helps. Does anyone know the part # or cross-reference #, also is there only one thermostat available for this engine or multuple choices like I've seen for some gas engines? I have a leak from the PTO clutch "bubble", I think it's just the o-ring leaking. Anyone know the part number for this, or something else that'd work? How hard is it to find an Oliver top link for this tractor? Mine has a reg top link end that works ok, but it's hard to make adjustments w/o a turn buckle. Is it ok to use a multi-season oil like Rotella T 15w40 in an untouched engine like mine? The guy I bought the tractor from told me to use only straight 40 weight, sorry I can't remember the reason why at the moment. If anyone can help me out, it'd be greatly appreciated.
AB
06-13-2006 20:39:43
 Re: ques. about 1650 dsl in reply to Rich Iowa, 06-13-2006 18:01:28
Hose part# 157 319-A
Thermostat part # 106 700-AS
O ring (1/8" x 8-1/4") part # 158 318-A I'm not for sure this is what you're talking about.
Your top link must be missing the lever that makes the adjustments easier. Part # for lever 101 436-A. Used top links are worth their weight in gold and probably are missing the lever also. To get by without the lever you need to adjust top link with implement weight off of the 3-pt.
15W-40 is probably fine in the summer. If you use it much in the winter you might think of changing oil in the fall to a 10W-30. I use a diesel rated 10W-30 year around. Call Ag Parts First 1-866-246-9720, O'Brien 712-324-4871, Farmersville 717-354-2150, Maibach's 330-939-4192 or others that have been mentioned previously and compare prices. If you get by one of those good old Oliver or White dealerships in Iowa they can also help you out. I don't think you want to fool around with a auto parts store for these items. FYI - the thermostat itself is close to $100.00.
evielboweviel
06-13-2006 18:36:22
toplink on ebay now, listed as for a 1600
call Maibach or one of the others for the tstat makes a difference on how the diesels run
Ron
