Help on Oliver 77 Diesel (update)
Newby
06-10-2006 15:19:35
Well, thanks boys for all the information. I have secured a complete overhaul kit for the engine. The instructions state to check to be sure block is at manufacturers specifications but does not list those specs. The new kit has pistons which are .250 larger than the original pistons but the sleeve deminsions seem to match. This is a 77 oliver fleet line not a super with the waukesha engine. The crank has 2 inch rod journals so I am not sure what the stroke is. Not a problem as I will be using the original connecting rods with the new pistons,pins inserts and busings. I would appreciate any hints or guidelines that you would care to share. Thanks
