I need transmission ideas
Jwondergem
06-07-2006 14:22:44
I have a growl in 3rd gear only. This is in a late 1850, ser. # 179-----. I was just in it and replaced the ring and pinion, counter shaft, and the pump, most bearings and all the seals. 3rd and 1st gears run the same, except for the range gear on the main shaft. The rest of the gears are nice and smooth. I'm looking for any ideas to check out that I might have over looked while I was in there. Next week I have to open it back up, because I must have snagged an O ring on the brake housing, and it's leaking. Right now nothing makes since to me, why it's growling in 3rd only. All the rest of the gears shift, and run real smooth. Any ideas will be appreciated very much. Thanks, Jack
