660 hyd. pump price
ahwv
06-07-2006 08:35:28
Pump was run dry for an extended period (had to use tractor, no time to stop and fix). Anyone know what it would cost to replace/repair. Thanks.
centerplate
06-08-2006 06:04:09
 Re: 660 hyd. pump price in reply to ahwv, 06-07-2006 08:35:28
You need to tear down the pump and inspect each piece. I can regrind the endplates, install new bearings, centerplate and seals. The gears are the big problem. AGCO no longer has them, unless you find a dealer with NOS parts. Used is the only option you have. I am in the process of making new gears, but I am not finished and have done no testing. All the gears I make are for the 77, 88 pumps. I have one drive sleeve for a 66. Email me with what you need in your pump and questions.
centerplate
06-08-2006 06:03:22
You need to tear down the pump and inspect each piece. I can regrind the endplates, install new bearings and seals. The gears are the big problem. AGCO no longer has them, unless you find a dealer with NOS parts. Used is the only option you have. I am in the process of making new gears, but I am not finished and have done no testing. All the gears I make are for the 77, 88 pumps. I have one drive sleeve for a 66. Email me with what you need in your pump and questions.
