OC12
Paw Paw
06-06-2006 10:20:42
The left steering is weak, an easy fix or adjustment? Also the hand clutch doesn't cam over and stay in place (I must hold back) and sometimes the clutch doesn't completely disengage. Any help would be appreciated. Thanks Paw Paw
DGH
06-06-2006 19:55:54
 Re: OC12 in reply to Paw Paw, 06-06-2006 10:20:42
First there are 3 types of steering used on the OC 12. The differential steering was most common. Could be adjustment or worn brake bands. The main clutch would be adjustment for not holding in, the draging is likely a build up of dirt and grease from clutch facing and release bearing. I would look for a manual on E-Bay!
