2150 hydrashift
Matt Page
06-03-2006 07:07:18
I'm new to this board, ussually hang around the Farmall folks, but of course like all of em the same... Have found a 2150 with hydraulic problems thats for sale and was wondering about this tractor... Anything you guys can tell me will be more than I know... thanks, Matt.
L Klingler
06-04-2006 11:41:10
 Re: 2150 hydrashift in reply to Matt Page, 06-03-2006 07:07:18
I have a OLIVER 2150 fwd with the lite rearend, same rearend as a 1955 with the tapered down axle. They allso were made with a heavy rearend, same as a 2255 with planitaries on the end of the axle. The heavy rear has a 14in. clutch, lite rear has a 13in. clutch. My opinion the heavy rear would be better, but than again that depends what you want to do with it. Larry?
dwm7
06-03-2006 13:30:46
Turbocharged version of the 2050 with a 478 Hercules engine. Came in 2wd and front wheel assist. I believe they were rated around 135 hp on the PTO, but probably exceed that. Probably external cylinder Category III 3-point if so equipped. The hydraul shift is a 3-speed shift on the go times 6 forward and 2 reverse in the main transmission to give 18 forward and 6 reverse speeds. It's a horse.
