OLIVER ID
DOUGMAN
06-02-2006 18:02:36
i have what i thought was an oliver super 77, the TAG has the spec #(17-0028) and the serial #(21541-705), the numbers on the engine also read 185220 with M100 underneath it. I am having trouble find information on it so anything will help
thanks
J Schwiebert
06-02-2006 18:17:02
 Re: OLIVER ID in reply to DOUGMAN, 06-02-2006 18:02:36
It is a Super 77. It is a 1955 model. It has a slow speed ring & pinon. How is that for a start?
DOUGMAN
06-02-2006 18:23:38
 Re: OLIVER ID in reply to J Schwiebert, 06-02-2006 18:17:02
that should help out alot, but why cant i cross reference the numbers on any of the websites i find
SherryS
06-02-2006 19:22:18
 Re: OLIVER ID in reply to DOUGMAN, 06-02-2006 18:23:38
Drop the last 3 digits off the serial number and you'll be able to match it up. The last 3 numbers represent the gearing in the tractor.
DOUGMAN
06-02-2006 19:27:10
 Re: OLIVER ID in reply to SherryS, 06-02-2006 19:22:18
i tried that and still couldnt find a match, any websites that u recomend
AB
06-02-2006 20:52:12
 Re: OLIVER ID in reply to DOUGMAN, 06-02-2006 19:27:10
If you look under serial numbers on the left side menu on this page search Oliver super 77 and this is what you get:
Oliver Wheel Tractors Model 77 Super Year Starting Serial Number 1954 8303 1955 10001 1956 38500 1957 44167 1958 56917
DOUGMAN
06-03-2006 06:53:10
 Re: OLIVER ID in reply to AB, 06-02-2006 20:52:12
but none of the numbers on here match the serial number on my tractor, the first digits on mine is 21541
Randy as in Randy-IA
06-03-2006 08:07:31
 Re: OLIVER ID in reply to DOUGMAN, 06-03-2006 06:53:10
That because your number lands after the 1955 year starting serial number of -10001 and before the 1956 year starting number of -38500 . It might have been clearer if he had put a dash between the year and the serial number . But that's what it is .
DOUGMAN
06-03-2006 07:07:19
i also forgot to say that on the axel it says rowcrop, and on the side paneling it says super 77, maybe the panels were replaced at sometime, but its confusing me.
J Schwiebert
06-03-2006 09:32:19
 Re: OLIVER ID in reply to DOUGMAN, 06-03-2006 07:07:19
Your panels should say Super 77. That is what the tractor is. On the axle housing. That casting was used on the 77, Super 77 and 770 Rowcrop tractors so it should say Rowcrop. More questions? J.
