88 belt pulley removal
jd plowboy
05-28-2006 09:52:31
how hard is it to take the belt pulley assy. off a oliver 88. do you have to have any special parts to put back on once removed. i would think it would take some kind of cover and could it be made.
J Schwiebert
05-28-2006 10:34:55
 Re: 88 belt pulley removal in reply to jd plowboy, 05-28-2006 09:52:31
Not hard to take off, 6 3/8 inch bolts plus 1 1/2 inch bolt. Yes, you will need a cover. It needs to hold the oil seal. You will also need to cover the hole where the oil runs in to the pulley. That can be fabricated from a flat plate and a gasket. I think there is one more hole also and a pipe plug goes in there. Part number for the assembly (cover) you are looking for is either KS 619 or 618. Have a memory loss. Any one off of any 77 or 88 will work. Questions?
jd plowboy
05-28-2006 11:26:39
 Re: 88 belt pulley removal in reply to J Schwiebert, 05-28-2006 10:34:55
where can i get that cover and will it be set up to hold that oil seal.
J Schwiebert
05-29-2006 18:22:02
 Re: 88 belt pulley removal in reply to jd plowboy, 05-28-2006 11:26:39
Back in the days when we stocked a new one the seal came as part of the assembly. You will also need to remove the seal wear sleeve to get the pulley drive gear off. The O-ring under the shaft will also need to be replaced. Where are you located or do you know of a parts tractor that maybe has one on. J.
jd plowboy
05-30-2006 17:43:29
 Re: 88 belt pulley removal in reply to J Schwiebert, 05-29-2006 18:22:02
i am in sc and we don"t have any dealers or parts tractors as i know of. i am the one that talked with you about the brake on the 88 hanging up.
jd plowboy
05-30-2006 17:49:44
 Re: 88 belt pulley removal in reply to jd plowboy, 05-30-2006 17:43:29
i found a cover on yesterdays classified ads that is not a original but fellow said would work just as good. it is a 3 bolt flange with a piece of pipe in middle. he said the seal goes in pipe and it has a ear welded on side for the clutch spring. talked with mark korves and he thinks it should work just as good as the original. i don't know just that's why i am asking a lot of questions
