fuel in oil once again Mr. Schwiebert
Jeff Oliver
05-24-2006 19:35:02
I had carried my 1800 diesel to respectable mechanics and they replced the seal in the pump,(3 rd one in it, 1st for them). It worked good for the last 3 months. Just checked oil again and there is fuel in it again, not as much but it is there... The pump was rebuilt last year and it is running on all cylinders with no smoke to speak of except in a hard pull.
Could it be possible that instead of replacing the bronze tube in the pump they instead lapped it out and for it too big for the seal? Also I haven't changed the rod that the seal goes on either but it doesn't look to be worn or have rust or anything, still shiney and smooth. Could it be worn and me just not be seeing it?
I replaced the transfer pump first thing last year thinking that was the problem and it is new from the dealer. Any other ideas? It is going back to the shop as they assured me that it was fixed. I have faith in these guys taking care of it I am just curious.
thanks!
J Schwiebert
05-25-2006 11:22:27
 Re: fuel in oil once again Mr. Schwiebert in reply to Jeff Oliver, 05-24-2006 19:35:02
I need more details and it is alittle bit like Don mentioned inn his reply. The funny part is I am getting ready to teach a different kind of engine class and in checking my notes I remembered 2 cases wher they had fuel in the oil because of sticking injectors because of low quality fuel. In both cases each engine scored one cylinder and ruined the sleeve and piston. Neither one of them had a dead cylinder either because enough heat was generated to burn some of the fuel. A guy in our neighborhood had the same problem with his combine. They even changed injection pumps. Problem was all injectors. So how much fuel do you generate in the pan and in what time frame and what are you doing with the tractor as far as load is concerned. J.
Jeff Oliver
05-25-2006 14:50:08
 Re: fuel in oil once again Mr. Schwiebert in reply to J Schwiebert, 05-25-2006 11:22:27
I thought about the injectors but everyone I talked to when this started said they would not make a differrence. I kinda thought it might. The engine is old as far as i know not rebuilt but I bought it at an auction. Doesn't seem to miss any but if the injector is not completly clogged that might account for that..
No real hard loads except for about 5 times hooking ot to an antique tractor pull sled and going down the track. Other than that we use it to load hay and little things like that. This last seal lasted longer than the others. Been in there about 3 months now as opposed to 3 hours. Any good way to check the injectors other than taking them out?
I haven't drained the pan yet but it seems to be about an inch or inch and a half above the full mark. Now right at 3 weeks ago it was fine as I checked it before taking it to the show/pull.
I am planning on keeping it and probably have more in it now than it is worth so i might pull the injectors and have them seen about and repaired/replaced if needed... Was hoping for something simplier than that though but ... :)
Thanks for the replies... i am slowly learning this stuff...
Oh and jak, yes I am getting tired of this problem. Keeps on I might have to switch to orange ones! LOL!!!
J Schwiebert
05-25-2006 15:24:44
 Re: fuel in oil once again Mr. Schwiebert in reply to Jeff Oliver, 05-25-2006 14:50:08
Any ideas how many hours you used it? Light loads are the worst condition for that. An old saying is all diesels use oil. If yours don't it is because of fuel dilution. An inch in three months, most of the time when pump seal leak you know it. There are always exceptions. I don't know about these people that have all this diesel knowledge. No one will ever know it all, but there are too many people out there with I have heard. How do they back up those claims? How quick does it start. A tired engine is going to make the condition worse.
Jeff Oliver
05-25-2006 18:22:12
 Re: fuel in oil once again Mr. Schwiebert in reply to J Schwiebert, 05-25-2006 15:24:44
It has been run maybe a total of about 10 hours or so. NO real heavy loads except for about 5 trips down a track which really is nothing at all. It starts really good except when hot I run into it not wanting to start once. Let it set for about an hour and it fired right off.
I know alot of folks who know " I have heard" but the mechanics I used this last time are good although their main brand is IH. I just talked to him and he told me at one time he had an IH doing this and the valves were way out of adjustment, set them right and the problem was gone, could this be a possibility?
There are no mechanics around this area that I know if that worked on alot of Olivers which is why I post on here alot. I do know where a 1650 is that runs good. May ride up there and listen ot it and see if mine sounds the same. Might not tell me a thing but it beats sitting here thinking of things when i don't know anything about diesels... Anyone ever heard of a pump shop lapping out the bushing to get the wear marks out instead of replacing the bushing the seal runs on? Maybe i just need to use the heck out of it :)
WFE 2
05-26-2006 05:15:41
 Re: fuel in oil once again Mr. Schwiebert in reply to Jeff Oliver, 05-25-2006 18:22:12
Personally I would be a bit wary of having that bushing lapped or lightly honed instead of replaced. We're talking some pretty critical dimensions here (maybe you can get away with it on an IH, but an Oliver is a precision machine:) )
All kidding aside, if it were my tractor, I would feel better about a replaced bushing.
Jeff Oliver
05-26-2006 07:30:32
 Re: fuel in oil once again Mr. Schwiebert in reply to WFE 2, 05-26-2006 05:15:41
That is what I was getting at. It was supposed to be replaced but I was wondering if maybe they honed it instead.
Jak
05-25-2006 10:21:43
Hey Jeff does it have lots of blow by?I bet your getting sick and tired of that by now.Jack
Jeff OLiver
05-25-2006 19:49:09
 Re: fuel in oil once again Mr. Schwiebert in reply to Jak, 05-25-2006 10:21:43
I haven't really noticed alot of blowby but from where I sit I can't see it very well. Do you remember seeing any when we were at the pull? Reckon I might as well fix the thing as I probably have more in it now than it is worth... Hummm now where can I find a good 3208 CAT to repower with..... .LOL!!!!
Don-Wi
05-25-2006 07:56:13
What kind of work does it do? How fresh is the engine? We were having similar problems with our Massey 285, only during the winter though. We went through 2 transfer pumps and it always went away, but we put the new pumps on in April right before the heavy feild work again.
During the winter it doesn't run hot enough to burn all the fuel(tired engine) so it washes down the cylinder wall and gets into the oil. We'd only put about 10-20 hours on in the winter, and it would be atleast 1-2 qts. of fuel.
Does this sound familiar at all?
Donovan from Wisconsin
