Farmall H brake bracket
SLH form MO
05-24-2006 19:22:22
I have 1949 farmall H and in front of the brake peddles is a L shaped bracket that runs out passed the two peddles. is this a factory item or did someone just add this .Thanks for any help.
JD in da UP
05-27-2006 06:16:48
 Re: Farmall H brake bracket in reply to SLH form MO, 05-24-2006 19:22:22
Like oliver fan, I don't know what it's for either but I'm not going to insult you. Our H doesn't have a bracket there that I remember, but it sits 20 miles away so I'm not able to check for sure. Good luck. John
oliver fan
05-24-2006 19:44:57
That bracket holds your tractor together. Don't mess with it or your tractor will fall into a million pieces.
Now that I have your attention, why don't you post your question on the farmall board?
