SUPER 55 3 POINT LIFT
Matt Kane
05-24-2006 18:38:38
I have an early super 55, and I am trying to figure out what is wrong before i remove the hydraulic cover. It will raise at around 1/2 throttle with no weight. If i put any weight on it it wont raise. So I replaced the filter and changed the fluid. Same thing, If I raise it up and turn it off, overnight it will drop. Any ideas before I tear into it?
Matt Kane
05-25-2006 12:17:02
 Re: SUPER 55 3 POINT LIFT in reply to Matt Kane, 05-24-2006 18:38:38
I drained it from the external control valve, and filled it where the dipstick is for the hydraulic fluids.
KENT
05-25-2006 12:00:32
WHERE DID YOU DRAIN THE FLUID FROM?---AND WHERE DID YOU PUT IN THE NEW FLUID?---IF YOU DON'T HAVE A MANUAL TO GO BY, IT'S EASY TO DRAIN & FILL THE WRONG PLACE---HTH
J Schwiebert
05-24-2006 19:01:33
You need the section out of the Oliver shop manual and not the I & T manual. The problem is internal. You will also need the use of a shop press to check it.
