Mr. J. Schwiebert on 1800 C
Johnnie T
05-23-2006 19:22:03
Mr. Schwiebert on the 1800C ser # 137424-847 on block # 157085 head 221 02 removed valve cover # on head is 157 086 have water in oil, man I bought from overhauled engine, thinks he installed wrong head gasket, when pulling it pushes water out overflow tube and was showing about 200 deg. on temp guage I think I have a model C with a model A engine cause it has 2 oil filters at a fast idle it pushes water out overflpw tube was wondering if that is the right head for this engine, could U shead any thoughts on thsi Thanks in advance Johnnie
Johnnie T
05-24-2006 06:41:47
 Re: Mr. J. Schwiebert on 1800 C in reply to Johnnie T, 05-23-2006 19:22:03
Mr. Schweibert both oil filters R "spin-on", canister fuel filter on right side, regular fuel filter on left RAB I am in connect with the man I bought from and we R talking maybe lowering the cost on tractor R I may be takeing tractor back to him depending on what I find out from all of U all Thanks for all info. Johnnie
J Schwiebert
05-24-2006 14:22:38
 Re: Mr. J. Schwiebert on 1800 C in reply to Johnnie T, 05-24-2006 06:41:47
Thank you for all your information. If you have more questions fee free to fire away. J.
J Schwiebert
05-24-2006 04:01:39
I forgot to ask you one thing and tell you another item. Are both oil filters "spin-on" and If you have the later B or C engine you should have a canster type filter and one fuel filter on that side of the engine. When you take it apart let me know what the numbers on the head gasket. Thanks. J.
J Schwiebert
05-24-2006 03:53:10
You are going to make me think a little bit and do some checking. Unless it rains both this afternoon and tomorrow my time is limited this week. The A series and later B & C engines do not use the same head gaskets. They have different coolant holes in the block and head. Your 157 085 & 86 numbers tell me if you have an A series engine it is a replacement block and head. How can I contact you?
RAB
05-23-2006 23:28:01
Johnnie T,
You wrote:
"man I bought from overhauled engine, thinks he installed wrong head gasket"
Depends. Is this Perkins or Waukesha. With a man who "doesn"t know" and "overhauls" an engine, I would be wondering what else it might be.
Head gasket improperly fitted
Wrong or damaged head gasket
Cracked head
Cracked block
Warped head
Incorrect liner protrusion
Even a warped deck
I may not be surprised if it were more than one of the above, but you may have an honest seller there.
Could also be a problem with liner seals as well. Who knows?
Hope you paid a commensurate purchase price, as it could be a more expensive job than just a head gasket.
RAB
RAB
06-08-2006 22:43:34
 Re: Mr. J. Schwiebert on 1800 C in reply to RAB, 05-23-2006 23:28:01
Johhnie t"s response posted down from much later:
Sorry about the delay on answering but been out on town,first the 1800, was A model engine in a C model tractor and checked head # to block # and was wrong head for the A block so put ity back together and took back, got money back and went to Nebraska and bought a 74 model 1655 that at this point runs like a top and everything works, got back Tuesday evening, Like driving and seeing the country, don"t like the traffibut thats life.
