Super 55 steering gearbox
Don Miller
05-22-2006 06:00:05
I need to replace/rebuild the steering gearbox on a Super 55. can a 55 be fitted with the power steering off of a 550 ?, and is it even feasible ?. any help with this would be greatly appreciated !.
Don
Johnny Mash
05-25-2006 21:53:48
 Re: Super 55 steering gearbox in reply to Don Miller, 05-22-2006 06:00:05
I know a man that has designed power steering for Super 55's and 550's go to jacksonpowersteering.com
MikeS55d
05-22-2006 13:40:28
It can be done but you need all of the PS parts off of a donor tractor. Unfortunately there are 50 people looking for Oliver S55/550 PS systems for every one that becomes available.
The non-power steering box is pretty simple, usually water gets in and kills the bearings. Bearings and seals are available, many of the parts are the same as Ford 8N etc.
Search the "Parts & Pieces" gallery (left side of this page) for "1957 Oliver S55" to find photos of the internal parts.
Don Miller
05-22-2006 17:23:22
 Re: Super 55 steering gearbox in reply to MikeS55d, 05-22-2006 13:40:28
MikeS55D,
Thank's for the info, I'm just going to rebuild the steering gearbox and be done with it. The steering wheel has a crack in it and that's how the water got into the gearbox. I'll
definitely purchase a new steering wheel when I come accross one.
Thank's again,
Don
jake4
05-23-2006 06:48:21
 Re: Super 55 steering gearbox in reply to Don Miller, 05-22-2006 17:23:22
Most owners don't keep lub into the case because it's not marked. It's located on the upper right of the gear box and accessed by removal of the bolt. The best lube is JD corn head grease or my dealer has 00 lube for $18.00 gal. This lub does not leak, a little expensive but cheaper than another rebuild.
