Hydraulics for 66 RC
John
11-01-1999 14:28:12
I have a 1950 66 RC with a mechanical lift. I have seen 77s with both single and dual hydraulic systems located below the steering column where my mechanical lift is located but I have never seen a 66 with this same hydraulic package. Were 66s built with hydraulic packages as an option? Are packages that would fit a 66 available anywhere other than a junk yard? Thanks in advance to you of great wisdom.
Dave
11-02-1999 07:50:27
 Re: Hydraulics for 66 RC in reply to John, 11-01-1999 14:28:12
The oliver 66 had 2 seperate hydraulic units. A early hydra Electric unit and a later unit with the longer dual levers. This was an extra option, and are hard to find. I have 5 66's one with hydra, and the other with the levers. I purchased on off of a junk tractor. Expect to pay $500 or more if you can find one. Oliver 77,88, units will not fit. Good Luck, DAVE
